AVG PC Tuneup not found
The previous message here, that you were not responded, I insist on that I suggest the possibility adding the new version of Tune Up AVG 2016, to me does not appear to me and I cannot find the way to erase cache and clean history for the following programs:
  • Disk Cleanner
- Registry Cleanner
- Others aplications in the Software AVG TuneUp.
until such times as Piriform add it to their winapp.ini file or the forum community update the entry in winapp2.ini, you'll have to add an INCLUDE yourself to get the job done.
But, how to use this winapp.ini ?
You'd use winapp2.ini, but you'd be making your own cleaner for it.
the winapp.ini (not to be confused with winapp2.ini) is 'internal' to CC.
it has the list of all things to clean.
you can see what's in it by using the /export switch and help using CC with switches is on their Documentation page on the web site.
but personally, all things I want CC to do above and beyond what's in winapp.ini, I do via INCLUDE's
It does not work, I installed winapp2.ini and not working:
I cleaned all logs Tuneup, but I still have the same problem.
add those log files by adding an INCLUDE to CC.
Here's the info on how to accomplish that:
http://www.piriform.com/docs/ccleaner/using-ccleaner/including-files-and-folders-for-cleaning
