AVG or Avast?
they updated the program version to 4.7.986 so you'll need to check for the program update again.
That is just a small update.
Version 4.7.986
April 18, 2007
-fixed the Outlook/Exchange provider on Windows 9x/ME
-solved incompatibility of memory scan with certain 3rd party applications
-fixed the boot-time scan under Windows NT 4.0
Just switched back to Avast myself very earily this morning since AntiVir still has update problems. No sooner did I download and install Avast and they updated the program version to 4.7.986 so you'll need to check for the program update again. Of course you'll have to restart Windows after it updates.
Thanks, done that.
