I received this annoying pop up from AVG when I updated the definitions today. Now we know when 7.5 will stop being supported. I wonder if AVG AS is going to be cut off then to?
The paid version will be supported until December I believe.
I did read that on Wilders. Hope so, because that is when my subscription expires.
You will get it for free now if you use AVG 8.0. If you don't use AVG AV than you will be SOL after they cut off support for AVG AS.
They should keep AVG AS around for the people that don't want to use AVG AV.
Aren't you the lucky one ?
It seems like you get all these pop-ups and I hardly ever get any.
We must be updating differently or something.I always update automatically or from the AVG 7.5 Control Center screen.
I updated today and did not get any pop-up from AVG.
I use only IE7 and the Windows Firewall and SpywareBlaster.
Guess I might as well switch over to AVG 8.0 and see how it goes.Memory wise and scan speed.
davey
Check out this thread about it's resources. The scan speeds are slower, but in no way is AVG 8.0 the slowest scanner around.
