Autoshutdown after cleaning
Hello,
there should be an option to shutdown the pc after cleaning
Already a well used and popular feature. Full instructions here:
http://forum.piriform.com/index.php?showtopic=16551
There is, look in Options\Advanced there is a checkbox that says Close program after cleaning. ;)
Why would you need this feature, anyway? CCleaner only takes seconds to run on my computer.
What is say, 5 seconds or less?
Can't wait for 5 seconds?
Gee, isn't that impatient?
I think he means shut down the pc, not the program.
Well I can make him a program that does that if he wants. ;)
