Does anyone have problems getting Crap Cleaner to autorun when windows boots up? cos I do!
I like to have my comp cleaned each time it boots and ccleaner did just this fine until now. For some reason when I check the box to "Run ccleaner when the computer starts", it wont save the setting at all.
It doesn't look like your doing anything wrong at all, as you only have to tick the box for it to autostart and then exit the application, it should add the autostart link in the registry immediately.
You can optionally have CCleaner automatically clean at startup by placing a shortcut in Start > All Programs > Startup:
