not anymore work , edge not auto clean after closing
i also test , if cc-cleaner ask about after closing, even that not work, cc-cleaner not ask about cleaning edge??
i have this pro version, disappointing
Maybe this will help:
23 hours ago, APMichael said:<div class="ipsQuote_contents"> <p> Maybe this will help: </p> <iframe allowfullscreen="" data-controller="core.front.core.autosizeiframe" data-embedcontent="" data-embedid="embed224555734" scrolling="no" src="<___base_url___>/topic/53177-how-to-disable-pre-launching-and-pre-loading-so-ccleaner-can-fully-clean-edge/?tab=comments&do=embed&comment=302353&embedComment=302353&embedDo=findComment#comment-302353" style="height:247px;max-width:502px;"></iframe> <p> </p> </div>
Yes, was probably ok help, thanks. I did first mentioned reg file with name in quotes and added that w double click to registry.
then restarted computer, after that some surfing w edge, closed it ..and i see cc-cleaner again working as before, autocleans edge.
sure there is in edge settings too possible some its own auto cleans when close browser, but cc-cleaner seems to find somemore,
as it works sometime even after little surfing.
I think restart is needed, anyway, if add that reg file. before that i did one test, not worked , if not restart computer.
The included readme file does suggest to restart the computer, unlike that topic. I haven't edited not knowing if a restart is needed or not in that topic due to all the full quoting done after my post in there since it would make a mess.
