Automatic cleaning of registry Issues
I would like a command line switch for registry cleaning, which will fix all Registry Issues, for example /REGCLEAN.
It sounds alright, however there are instances where it's best to know exactly what Issues is going to remove. For one Issues isn't only a registry cleaner - it cleans shortcuts, etc., and I've witnessed in the past where CC's Issues scanner wants to remove valid shortcuts.
But if you could specify the different type of scanning you wish to make in an INI-file and then clean all errors. and specify the INI-file as a parameter
Example:
MissingSharedDLLs=1
UnusedFileExtensions=1
ActiveXandClassIssues=0
1 if it is checked, and 0 unchecked.
Hi all,
Need help...I run the Spyware Doctor and detected 1 infected file with Trojan.Downloader.Small.CML as follows:
1. Infection Name
2. Location
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP183\A0023015.dll
Any idea on how to remove the infected file? Pls advise....
Appreciate it (your help/advise)
wolfiee, welcome.
The C:\System Volume Information\_restore file that is infected and should be removed.
Disable System Restore then enable it to create a good Restore point:
http://www.pchell.com/virus/systemrestore.shtml
Install prevention protection to help prevent re-infections of your system:
Download then install SpywareBlaster and keep it up to date at least once per month.
http://www.javacoolsoftware.com/spywareblaster.html
Install SiteAdvisor as it shows an an indicator of bad sites you are visiting:
http://www.siteadvisor.com
Install MVPS HOSTS file to block ad tracking cookies and many malware sites:
http://www.mvps.org/winhelp2002/hosts.htm
Keep it up to date at least once per month.
Install ALL prevention protection recommended and keep them updated regularly by reading the announcements at Calendar of Updates
Hi all,
1. Infection Name
2. Location
I see you have also posted in the hijack this log section. That is the BEST thing to do as a qualified spyware mod will help you.. Post a log by following the instuctions given here
http://forum.ccleaner.com/index.php?showtopic=1720
