automaic shutdown
gday everyone,
i have a cousin staying with me for a while and i told her to go to bed before midnight but instead she stayed on the computer until 3am in the morning!
does anyone know a program that allows you to control when the computer gets to shutdown? like a set timer thing?
please suggest.
thank you.
Already built into Windows XP.
Start a Command Prompt and type in: Shutdown /?
From there you can determine what you want to use. Test it first!
30 second example:
SHUTDOWN -s -t 30 -c "System Shutdown"
You can also schedule it via the Windows Task Scheduler, which I suppose is what you'll want to do for it to be automatted.
Special note: If you use it you'll need to give enough time for the person to save any opened documents, don't just pull the plug on them that would be rude.
how do i start a command prompt?
thanks.
Start > All Programs > Accessories > Command Prompt will get you there.
30 second example:
if you want to do that, just type in your "code" into notepad and save it as ANYFILENAME.bat
then go to task scheduler and set it to run that program at a given time.
if you dont want them getting back on, put a password on windows.
(if theyre smart, when the shutdown starts, they can just go to run and type shutdown -a and that will abort it.
thanks Greeknight.
but does anyone know an actual program that does this sort of thing? i dont like to use the windows XP built-in version.
the site is here, http://www.codetools.com/system/ShutDownAlarm.asp
i havnt had time to try it so im not sure if its what your looking for. good luck!
heres the download to try, you had to log in so i thought it easier to just upload it!
If you got a Linksys Router, you can do that too. I'm not sure if you can do it on all routers though.
thank you so much. just what i was looking for! :)
glad to see it helped!
i have a linksys router but i havent found that function. how do i get to it?
