Auto Shutdown
Hello Piriform CCleaner developer,
i have a suggestion to the "shutdown after cleaning feature" in CCleaner.
It would be nice if you put a new checkbox with the function, that the user can decide wheather he wants that auto-shutdown function is always active, when it was activated or that the user must activate the function always by himself when he starts the cleaner.
Reason:
My Problem is that i start the cleaner and sometimes i dont want to shutdown the pc after cleaning. But because i checked the auto-shutdown-function the last time in the tray and forget to disable the function. Then i just start the cleaner when im working and suddenly the pc shutdown. This is bad, when im working on important things and then they all gone...
Thanks!
Hopefully the devs will fix this soon, see here
http://forum.piriform.com/index.php?showtopic=40131
