Audio converter
I'm looking for an audio converter primarily to convert .ogg to .mp3.
Are there any decent freeware programs out there or must I go commercial?
I have noticed this product, but needless to say you have to pay for it...
Audio Wizard
db poweramp 10(last freeware version)
http://www.aplusfreeware.com/categories/Au...dBpowerAmp.html
Thanks rridgely...I actually found version 11 a minute ago and should I purchase it it is much cheaper than the earlier link I provided.
You don't have to buy anything, what's listed below is completely free or open source software.
1. Download oggdec v1.9.2.
2. Download LAME 3.97b2, the package that contains lame.exe. Note: It's the best mp3 encoder!.
3. Download ALL2LAME.
4. Unzip ALL2LAME into it's own folder such as C:\ALL2LAME.
5. Unzip oggdec v1.9.2 into the C:\ALL2LAME folder.
6. Go here to find out how to encode at your preferred bitrate/quality. Input that bitrate/quality you want into the ALL2LAME switches area.
7. Add your ogg's into the ALL2LAME window and click Encode.
And since you'll be transcoding ("converting") your audio files I highly recommend that you keep the original .ogg audio files, hence transcoding from one lossy format to another one will cause a loss of quality.
If you need any specific information or help configuring ALL2LAME just ask here and I'll help you.
It is probably a better idea to keep the files as Ogg Vorbis instead of converting them to MP3 if possible.
Because Ogg Vorbis provides better compression and higher quality.
Agreed!
However I suspect he wants mp3's for a portable player which would make sense, although re-ripping and encoding directly to mp3 from the original CD's would be the best choice to have the best quality mp3's versus hideous transcoding.
I know Ogg Vorbis does a better job than MP3, my problem is that I can only download the needed music in ogg format.
F
rom there I need a way to convert the ogg files to both mp3 and wav.
So far db poweramp is catering my needs, but I do appreciate the alternative way you indicated Andavari.
Yeah my way is probably the slower more involved way of doing it. I just hope dbPowerAmp can copy the tag's from the ogg's into the mp3's so that you aren't having to re-tag everything.
