Since you've already been in the registry also check in your user profile 'Application Data' folder, and 'Local Settings\Application Data'. Both are hidden folders so you'll need to enable the view of Hidden Files and Folders in Windows.
Worked perfect.
I'm on Win 7 32 bit so I removed the "Opera" folders under:
