Hello,
I have two questions about v2.06.567
First, if I select "Cleaner" and then "Applications" tab - why do some of the applications have asterisks next to the name?
Second, where can I find a list of exactly what is cleaned for each application. For example, CCleaner apparently removes the autocomplete names list from Outlook. What else does CCleaner clean from Outlook - where can I find the list for each app?
Thanks
NM
