Hello
When i run the CCleaner in the aplications tab i have programs that are not instaled?
How can i fixe that?
Tank you
Hello
Tank you
What programs are listed that you don't have?
Opera browser.....
I have instaled firefox
Did you have Opera at one time?
Yes...but not now
That's why then. Opera didn't remove all of the registry keys.
Well tell him how to remove it!
Issues part of CCleaner would more than likely be best to start.
Well I just realized that the opera detection key is special or something and is not listed in winapp.ini, so MrG will have to tell us what key is used to detect Opera...
I m waiting.....ehehe
Wow, with that kind of attitude maybe you should wait longer. I told you a potential solution. You want to ignore it or not state whether or not you tried it then do not expect further assistance.
I m sorry...
Can you please tell me how to resolv the problem?...please
Tank you
It's alright. Have you tried running the Scan for Issues under the Issues tab of CCleaner a few times and cleaning out anything found?
Yes...i have run a hundred times...and nothing....
Have you looked for any folders pertaining to Opera? If on XP, also check in Documents and Settings\All Users and such.
I have made a full search and i didnt find anything....
I just find this file "OPERA.EXE-3B75DA17.pf" in directory c:/windows/Prefetch
Try deleting it, though it shouldn't be related.
Click Start, Run...
Copy and paste this into the box and hit OK:
cmd /c reg delete HKLM\Software\Opera
and also:
cmd /c reg delete HKCU\Software\Opera
See if that helps.
You can also trash that prefetch file you found, no biggie.
Didnt work...................
