Is there anyway to login to a ccleaner portal to see which computers are using ccleaner license numbers?
17 minutes ago, twostreets said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> Is there anyway to login to a ccleaner portal to see which computers are using ccleaner license numbers? </p> <p> </p> </div>
Are these computers in your home?
21 minutes ago, hazelnut said:<div class="ipsQuote_contents"> <p> Are these computers in your home? </p> </div>
No, they are computers that my remote workers use all around the country.
1 minute ago, twostreets said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> No, they are computers that my remote workers use all around the country. </p> </div>
Then it would be best for you to contact Piriform directly as you obviously have a business licence.
Either
https://support.piriform.com/hc/en-us/requests/new
or by email to
support@ccleaner.com
28 minutes ago, hazelnut said:<div class="ipsQuote_contents"> <p> Then it would be best for you to contact Piriform directly as you obviously have a business licence. </p> <p> Either </p> <p> <a href="https://support.piriform.com/hc/en-us/requests/new" rel="external">https://support.piriform.com/hc/en-us/requests/new</a> </p> <p> or by email to </p> <p> support@ccleaner.com </p> </div>
Yes thank you, I shall ultimately do that.
However I was just wondering if there was a way I could logon somewhere and see who was using which licenses at any time.
12 hours ago, twostreets said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> However I was just wondering if there was a way I could logon somewhere and see who was using which licenses at any time. </p> </div>
If you are using CCleaner Professional or CCleaner Business Edition, note that those are unmanaged endpoint products and not designed for that sort of thing - as the assumption is that all of the devices would generally be in the one household or business premises.
CCleaner Cloud is designed specifically for businesses with 10+ computers, or where some form of remote management is desired - and you should be able to see client usage information in the management console.
