Another Problem
This is just a pain in the neck. I cannot see the address bar in folders. On IE, thats fine, but if I click Address Bar in a folder, all I get that comes up is a bit of text on the far right just saying "Address". All help would be appreciated.
And yes, I have followed these instructions that Help and Support gives:
"Open Folder Options in Control Panel.
Click Start, and then click Control Panel.
Double-click Folder Options.
On the View tab, select one or both of the following check boxes:
Display the full path in the address bar
Display the full path in title bar "
Did you deselect View > Toolbars > Lock the Toolbars and try to move the Address bar to another area of the toolbar? It may just be so far to the right that the field isn't visible.
You my friend are a legend. Excellent, its all working now, you were right about the locked toolbars, will remember that in future. Cheers.
