Analyze & Run cleaner's buttons not showing correctly
I have a similar problem. Unlike your situation, however, my "analyze" and run cleaner" buttons aren't grayed out--they're missing altogether. That, of course, renders cc cleaner completely useless, as the program can't be run.
I've uninstalled and reinstalled cccleaner, to no avail. Anyone know of a program similar to cc cleaner? Because Piiform's version doesn't perform. (Almost rhymes. doesn't it?)
memphisbelle11 what is your operating system?
Do you have any 'start programs' such as classic shell?
Any different Windows 'skin' you are using, or is everything the default?
Just as a test if you change your screen resolution do the buttons show then?
http://windows.microsoft.com/en-gb/windows-vista/change-screen-resolution
