Analysis Failed - 3 TB USB external drive
I am new to Defraggler; I just installed v2.07.346 and things seem to be fine so far on my internal HD, a 250 GB SATA Seagate. However, on my external HD, a 3.0 TB SATA Seagate GoFlex, Defraggler can't analyze it. After looking at the Health tabs of each drive, it looks like the Buffer Size on the GoFlex is listed by Defraggler as "Unsupported" (see two attached screenshots). Is that the reason that I'm getting an "Analysis Failed" message? If so, will future versions of Defraggler resolve this problem?
Hi DCB, and welcome to the forum.
A possible issue with larger drives has been reported and acknowledged here ...
http://forum.piriform.com/index.php?showtopic=33887
Hope that helps/
Thanks, DennisD. It does help. I guess i'll have to hope that some future upgrade will solve this problem. :unsure:
