Analysis and Defrag Results
I am running Deftaggler on two different computers. On one, when the defrag completes, I see both the analysis and defrag info. That way, I can see what it was and what it is now.
However, on my other computer, it only shows the results of the defrag (not what it was before). The versions are the same. I can't find a difference in the options between the two.
Anyone know what I can do to get the before / after results to show up once the defrag is complete?
Thanks.
I figured out the solution. The bottom third of the screen wasn't big enough. I reduced the size of the other components (list of drives and "blocks" for lack of a better term). Now when the defrag is done I can see the analysis results and the current results.
