Always on top
PLEASE add option to set speccy window to always on top.
It is such a simple feature but would make my life so much better.
I need to keep an eye on my temperature over time, and would love to not have to alt-tab the speccy window to the front over and over. :)
did you know you can have Speccy in the System Tray, always showing your temps?
in Speccy > View > Options > System Tray tab, click Minimise to tray, tick the two Display metrics options, then in the Output field, tell it the temp to show.
also tick Run Speccy when PC starts if you want that feature.
Although this does help me a bit, i still would really like always on top.
I usually have my toolbar on “show on mouseover”, so its not always visible.
But thank you for the tip. It does help a bit. :)
