Always in recycle bin
C:\$Recycle.Bin\S-1-5-21-1233076576-3951402979-1630808504-1001\$R8TGUYL.lnk
is always deleted but listed twice in recycle bin
log.txt
Shows up twice in log & files deleted list
Is it safe just to add to Excluded list?
Have a read of all this page here, it may give you some ideas
https://www.howtogeek.com/forum/topic/what-is-recycle-bin
When I use "analyze' IN CCLEANER IT WILL SHOW THE RECYCLE BIN EMPTY. Then after I click 'CLEAN IT WILL SHOW 30mb cleaned from the recycle bin. This happens every time. What is going on?
It may be that your recycle bin has become corrupted. It does happen and while confusing it's not a serious problem.
See this for how to reset/fix it -
https://www.thewindowsclub.com/recycle-bin-is-corrupted-windows
