I constantly have to log into Netflix.(user name/password) CCleaner always deletes the cookies.
Although I have excluded the cookies from Netflix.com for CCleaner, the log in page for Netflix (netflix.com/login) never appears in the exclusion list.
I can't find a way to add this address manually.
Are you using Options > Exclude to keep the cookies?
If so, login at Netflix then close your browser. In CCleaner go to Options > Cookies and move the cookies from delete to keep using the ->.
I have two cookies from Netflix, "netflix.com" and "www.netflix.com" both non flash cookies.
I also have those Netflix address's to exclude. As mentioned above, the login page (www.netflix.com/login) never appears on the list so I cant move it to the "allow" side.
It doesn't show up for me as well. What makes you think there should be a cookie (www.netflix.com/login)?
With the two saved cookies I have, the site remembers me and I'm automatically signed in to Netflix.
The www.netflix.com is probably the login cookie. Is your browser set to remove cookies at the end of the session? If so, the Netflix login cookie will get deleted whether it's in the CCleaner exclusion list or not.
