Hi.
Does anyone know how to delete the new Air and Silverlight Cookies?
Hi.
Hi gust.
Not having Air or Silverlight I can't check this out, but from a little research I believe they'll be using Flash Cookies. Whether they are the standard "settings.sol" files I don't know, but have a look in the following locations.
C:\Documents and Settings\Compaq_Owner\Application Data\Macromedia\Flash Player\#SharedObjects\PG6EKNTG
The bold number will be different on your PC.
C:\Documents and Settings\Compaq_Owner\Application Data\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys
Let us know if you find anything, and maybe one of the other members here will be a Silverlight or Air user.
If you find them, you can add the files or folder to CCleaners "Include" feature. "CCleaner\Otions\Add File or Folder".
You would need to check the "Custom Files And Folders" box in the advanced section for this to work.
Hope that helps.
