Ahora No funciona AdBlock Plus
Desde que he instalado la versión de pago de CCleaner el bloqueador de anuncios Adblock Plus no funciona en YouTube, antes no tenía anuncios y ahora es continuamente
That is You Tube not CCleaner.
There is a constant battle between you tube and adblockers, sometimes the blockers win sometimes you tube wins.
Give it a while and Adblock Plus will update and start blocking them again
Gracias.
