After using CCleaner, System Restore fails already
:o
I have been using system restore before in my system and it never fails.. I just used it to reset some important things that i won't mention anymore.
Just now, I installed CCleaner to try to enhance my PC. I didn't change any settings in my PC or in the CCleaner (it means the settings are in default). After using the File cleaner and Registry cleaner of CCleaner, I felt good about it. After several minutes of work, I needed to do system restore for I accidentally did something wrong. I run the SystemRestore tool which had a restore point that was made before I installed CCleaner. After restarting the PC, a notification appeared which said that SystemRestore failed to perform successfully and it didn't changed my files and settings. The notification also says that it happened because of an unspecified error. This just happened when I installed CCleaner. My brother also told me that this also happened to him after using CCleaner but he doesn't know how to fix it.
If you may please help me fix this issue. Thank you very much and have a good day... :rolleyes:
:o
Did you ever get a reply to this?
