This afternoon I ran the cleaner, as well fixing registry issues. Now Windows 10 is extraordinarily slow on restart and other functions. I also now have MS Office error code 0x426-0x0. I cannot run any Office programs and have tried solutions presented online, which have not worked. Can someone please help? Thank you.
Did you make a back up of the registry issues you cleaned when CCleaner offered you the chance to do so?
Do you have any system restore points from just before you did the clean?
Thank you for the reply. Having a registry backup didn't matter as the computer ran extremely slow and crashed on attempted fixes. Had to ensure all files were backed up and then have Microsoft wipe the OS and reinstall. Apparently Ccleaner indiscriminately deletes Windows OS files. I also have been told that it increases the number of ads that appear in browsers. I will no longer use Ccleaner.
3 hours ago, vlane said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> Apparently Ccleaner indiscriminately deletes Windows OS files. I also have been told that it increases the number of ads that appear in browsers. </p> </div>
Neither of these describes something ccleaner does. The first means you removed something that shouldn't be removed. When using registry section of ccleaner it's best to follow the advice in my signature below this post.
The second is pure fiction, ccleaner does not increase (or decrease) web advertisements.
