AFTER USING PERIFORM PRODUCTS LIKE CCLEANER & REGISTRY CLEANER, OR OTHER FIXES, OR USING OTHER SUCH PROGRAMS PURCHASED, DO THE FIXES REVERT COMPUTER TO THE SAME MESS IT WAS IN BEFORE USING PIRIFORM FIXER / CLEANER PROGRAMS -IN ORDER TO GET CUSTOMERS BACK ?
P.S. -As I said, -AFTER REMOVING THE PROGRAMS OR EXPECIALLY AMONG COMPUTER-PAY PROGRAMS -AFTER THE EXPIRATION DATES ? AFTER THESE DATES OF REMOVAL, DO THESE AND PAY FIXER / CLEANER PROGRAMS SAVE, AND THEN DUMP THE PROBLEMS BACK INTO OUR LAPS, THAT THEY CLEANED UP THE 1ST TIMES ? -Thank you, -In_SameBoat87
what are you saying??? and why are you shouting?? please turn your caps lock off and try to make at least some sense.
What goes back to the way it was?
Are you using the Cleaner section or the Registry section
Please instead of making multiple posts edit the first one until someone (like this post) answers, then create a new post. and Please keep the caps lock turned off it's very bad etiquette.
EDIT:
If I understand your last question. No, the things removed do not magically return when the cleaner is removed.
