adware and spyware
Does CCleaner find and remove adware and (or) spyware?
I am afraid CCleaner is not a spyware/ adware remover.
Are you having problems in that area?
Not really....I was just wondering. I have Bit-Defender on my machine and it doesn't like
AdAware or Spybot so if I want to run those I have to disable BitDefender, install AdAware,
run it and then uninstall it and enable BitDefender. (Pain in the butt.)
Thanks
The question is does Ad-Aware or Spybot S&D find anything to remove other than tracking cookies?
If they find adware or spyware then you need to block them with the HOSTS file, Windows Defender and WinPatrol.
HOSTS files I use:
http://www.mvps.org/winhelp2002/hosts.htm
http://hosts-file.net/?s=Download
Managed with HostsMan and I use its HostsServer proxy to speed up browsing:
http://www.abelhadigital.com
