Advanced options
Hi,
I am using to Ccleaning, but i have not click on the advanced option up to now.
Do you recommend I click and use some of the advanced options, and which one
do you recommend to use as I clean up.
And without usind the advanced option do u clean up cache files on my computer.
Regards and thanks
Jean of Montreal
IIS Log Files
IIS (Internet Information Server) is the service Windows uses to display web pages. This comes with most XP Pro and Windows 2000 installations and is generally only used by web developers or designers. Every time someone requests a page it gets logged to a text file. Unless the computer is a web server, these are generally not needed, and may be safely deleted. This option will safely delete these files.
Menu Order Cache
The Start menu allows you to set a custom order to the programs listed, although there's no option to sort all folders by name. Selecting this option removes any custom ordering from the Start menu.
Tray Notifications Cache
In Windows XP the System Tray (the set of icons next to the clock in the bottom-right corner) orders and hides items automatically for you. Whilst this is useful, it records a list of every program that has been run from the tray. This option clears the list of previous programs and removes any custom display/hide options. (Warning: This won't have any affect until you manually restart the explorer process from the Task Manager.)
Window Size/Location Cache
Windows Explorer stores the view formatting and ordering settings for each folder on your system. After some time, this can contain a large amount of redundant data and may even slow down browsing for files on your system. Selecting this option will clear this data and reset the Windows Explorer display settings to their default option.
User Assist History
The start menu on Windows XP displays a list of the most recently run programs. Selecting this option will clear this list.
Hi,
Thanks for your reply, but on my CCleaner, which one should I used in the
advanced settings and how ofter should i clean in that advanced setting.
IIS Log Files
Menu Order Cache
the above is not clear to me, sorry, where do I go for that...
The above, where do i get this option where it clears....?
Restart the explorer is it restarting the computer....?
For the above, where do i go for clearing the caches, again where do i go for
selecting this option....
User Assist History
The obove is ok with me
Many thanks again for your reply
jean from montreal
the choice is really up to you... :) when you feel it is time to clean, then just check those checkboxes and run CCleaner... when it finish uncheck it if you want to... :) i personally dont clean the 'Advance' section often...
IIS Log Files
Menu Order Cache
you might just want to left the IIS Log Files checkbox checked... basically log files are just files with a list of actions a particular application performed... these files are useless unless you want to do debugging etc...
is all the little icons you get beside the system clock... in WinXP, Windows remember the setting of these icons... whether they are set to 'Always hide', 'Always show' etc... you can view these by right clicking on the task bar and select properties...
you need to terminate Windows Explorer manually... bring up the task manager and under 'Processes' tab, search for 'explorer.exe' and end it... then go to File -> New Task (Run...) and enter explorer.exe to bring up the explorer again... ;)
i not sure where can you find this... but folders have their own settings... like whether files and folders are view as Icons, List etc... and when you change these setting, Windows have to save it, taking up spaces... so cleaning will reset them to their original state...
hope all these does help...
I checked my Advance button and I don't have any of the choices you answered about. I have:
Only delete files in temp files older than 48 hours.
Hide wanring messages
Close program after cleaning
show promt to back up registry issues
show detailed log of Internet Explorer Temp files
Where are the choices to check tray notification cache, etc....? :huh:
no no... is not the options... is under the CCleaner application main window... under the "Windows" tab... there is a section called "Advanced"
Gotcha...OK. When it says I need to restart the explorer.exe process, do I do that through Task Maanger and type in explorer.exe? :(
One of those Advanced cleaner settings removes the Quick Launch bar without the ability to have it stay re-enabled after cleaning. I don't know which one it is though since I quickly restored the registry to get the Quick Launch bar back.
thanks....I think I will just stay away from all of those Advanced settings for now...I appreciate the help. :)
Gotcha...OK. When it says I need to restart the explorer.exe process, do I do that through Task Maanger and type in explorer.exe? sad.gif
yup... launch task manager and launch explorer.exe :)
