Advanced cleaning
Hey all.
The program is great, I've been using it for quite a while.
Once I knew I wouldn't be needing the Hotfix uninstallers I would use the Advanced cleaning setting and get rid of them. There are now a lot there again that would be safe to ditch, thing is when I select the advanced options and run an Analyze to see how much ccleaner could get rid of but it doesn't seem to pick up anything.
I will analyze the regular junk, ( lets say it picks up 30Mbs ), then check off the advanced options and analyze again but get the same number. There has to be more, I haven't run the advanced clean in a long time.
I guess I could go ahead and run it with the advanced checked to see if it cleans the stuff but I would like to know how much will be cleaned.
Thanks
The latest version of CCleaner doesn't appear to be picking up the hotfix uninstallers. Hopefully will be fixed in next update. Most of the items under advanced won't show any actual space to be cleared anyway, only Hotfix uninstallers, prefetch and custom folders (if any selected)
