Advanced Cleaning Options
So i decided to share this REG file i made to have more cleaning options on the Recycle bin.
When you successfully installed it, it will look like ...
Rest of post removed by moderator.
Using 3rd party reg scripts which use other cleaning products is not allowed in the Ccleaner forum discussions.
