Advanced Cleaner
Hello
It would be great if CCleaner can contain a module such as an Advanced Cleaner to delete certain file types.
Today, for CCleaner, the user have to write all file extensions to delete and may not be the optimal situation for this kind of cleaning. Threre are nothing to select by recommendation.
The idea is to have a kind of Advanced Cleaner such as what we can find in Wise Disk Cleaner. The user can quikly select the file extension to delete, has several modes to select (Recommended, All, None), among other setting features.
Thanks
