Adobe Flash Player
For a week or so now, adobe flash player has not worked. I have tried all the fixes I can find from adobe. I have tried several of the variations for > tools > internet options > security, including the ones recommended at the adobe site. Now am back at default.
There is apparently a problem with the recent flash updates, from the comments over at the adobe help forum. pwillener is working pretty hard, but I don't think its getting fixed.
Adobe Forum
2 questions. For adobe flash player to work, is it necessary to set > tools > internet options > advanced to enable script debugging? and
Is there a viable alternative for adobe flash player?
Thank you.
edit: It's fixed, shockwave flash player was disabled in > tools > manage addons. Don't know how it got that way.
You never know Login, what you found about the shockwave player bieng disabled affecting adobe flash, may help others when they google and land on your post.
