After I run CCleaner I can't play anything requiring Adobe Flash Player. I go to Adobe and reinstall the latest version, but the next time I run CCleaner, same thing happens.
Is there a setting I can change to stop CCleaner from removing Adobe Flash Player? Or any other suggestions?
As nodles says you shouldn't have to keep reinstalling Flash.
Do a clean with ccleaner, install Flash, reboot, then do an analize with ccleaner and look in the list to see if you can see anything which looks like it's concerned with flash. Let us know what it shows or do a screenshot.
Are you using the registry part of ccleaner when you do a clean?
