Adobe Flash Player 11 Beta for Desktops
Features:
Stage3D APIs ? Create highly interactive visuals to improve collaboration on 3-dimensional models.
64-bit support ? Support for 64-bit operating systems and browsers on Linux, Mac OS, and Windows.
G.711 audio compression for telephony ? Integrate voice/telephony into business apps using G.711 codec.
H.264/AVC SW Encoding ? Encode higher quality video locally using H.264 video.
Socket Progress Events ? Build advanced file sharing apps like FTP clients that send large amounts of data.
HD surround sound ? Deliver full HD videos with 7.1 channel surround sound directly to AIR powered TVs.
Details: http://labs.adobe.com/technologies/flashplatformruntimes/flashplayer11/features.html
Download: http://labs.adobe.com/downloads/flashplayer11.html
Release notes: http://download.macromedia.com/pub/labs/flashplatformruntimes/shared/flashplayer11_air3_b1_releasenotes_071311.pdf
Please note: any earlier Flash Player versions must be uninstalled before installing the FP 11 beta.
Any problems with the FP 11 beta can be reported at the Flash Player 11 forum .
Adobe Flash Player 11 Beta 2 is now available for download. This update provides added stability.
Features:
Release notes: http://download.macromedia.com/pub/labs/flashplatformruntimes/shared/flashplayer11_air3_b2_releasenotes_081011.pdf
Nergal
August 11, 2011, 2:48am
4
sweet, lots of cool stuff coming to a flash enabled devices near you...& me too.
and in a Flash your battery life hits rock bottom.
I hate Flash it's CPU intensive crap unsuitable for running on portable devices unless you have an ARMv7 processor.
Also why do 3rd party tools do a much better job at handling flash content i.e. XBMC or Google's YouTube video player??
Richard S.
die flash die.
Firefox 8 (Nightly) does not detect the 64bit version of Flash 11
Rather it is above the max version allowed in blocklist.xml, I've come to speculate.
Come on say what you really think of it. Seems like so many sites just like to Flash you these days.
It causes me more grief than it’s worth, I think, sometimes
Nergal
August 12, 2011, 10:23pm
9
What happens if you manually edit max version in blocklist so that it is no loinger above?
Haven't tried, but I will and will report back on that one.
looking through this file, I've come to believe that it's more for extensions than plugins, but I can't be sure
Doing a complete uninstall of Flash 11 and a reinstall with the 64bit installers seems to have worked. Not sure if this is related to the fact I deleted the blocklist.xml contents, likely not.
Aethec
August 22, 2011, 9:59am
12
Flash is already unstable enough... these should be called alphas
waiting for the new alpha version since i dont like unnessesary messing around with my system, seems to provide a lot if nice upgrades, at least it promises to. But knowing flashplayer they always develop, give them some time.
They usually develop more problems
Adobe has enough issues with the "stable" release versions, I wouldn't touch it in the alpha or beta stage.
Adobe Flash Player 11 Release Candidate 1 (v11.0.1.129) is now available for download. This update provides added stability.
Features:
Stage 3D Accelerated Graphics Rendering — Deliver cutting edge 2D and 3D experiences on the desktop.
Native 64-bit support — Support for 64-bit operating systems and browsers on Linux, Mac OS, and Windows.
G.711 audio compression for telephony — Integrate real-time voice and telephony capabilities into business apps and integrate with existing phone systems using the G.711 codec.
H.264/AVC SW Encoding — Create apps that encode higher quality video locally using the efficient H.264 video standard.
Socket Progress Events — Improve management of data transfer, track progress, and provide responsive feedback in apps send large amounts of data.
JPEG-XR support — Take advantage of support for the advanced JPEG-XR image compression format to deliver higher quality images with less bandwidth, and leverage lossy and lossless compression with alpha channel transparency.
Details: http://labs.adobe.co...1/features.html
Download: http://labs.adobe.co...shplayer11.html
Release notes: http://kb2.adobe.com...psid_91694.html
Please note: any earlier Flash Player versions must be uninstalled before installing FP 11 RC1.
Uninstallers:
I'd personally like to see them remove the jerkiness in Flash videos like some on YouTube, etc., caused by all their recent updates.
Word. Id rather stick to alpha versions of flashplayer.
I try new versions. I mean, come on, if you have all your stuff backed up, whats the worst that can happen? Ur computer melts? LOL!
Goodness!
