Adobe Flash has advanced to version 11.1.102.62. But it still sucks. When I open a folder with one or more *.FLV files in it then Windows (XP) becomes (more) sluggish / less responsive and it takes Windows Explorer (significant) more time to display the content of those (and other) folders. It also takes XP (significantly) more time to switch between running programs.
Taskmanager shows that from time to time CPU usage spikes up higher and usage even can reach 100% for a number of minutes. I extract those *.FLV files from the temporary internet files folders. I didn't install Quicktime with this or the previous version of Flash. So, that's not the cause for this sluggish behaviour. Do other user have similar problems ?
Sometimes navigating the Adobe site can be a minefield there are so many Adobe sites with conflicting info on when a new build comes out, sometimes the download page even downloads the old version
So I wait a couple of days and get the FileHippo one with nothing bundled... just easier I guess. Plus any reports about problems with the new version will have been put on different forums by then
Getting the installers from FileHippo is significantly easier! I just wish FileHippo also hosted the Flash Uninstaller, then I wouldn't bother with Adobe's site.
All the newest versions are either Betas or Release Candidates (RC). Seems Adobe knows Flash needs to be (dramatically) improved. Don't know if I am going to install the latest version any time soon. But the Adobe website also said that v11.1 wasn't succesfully installed on my laptop. Ouch. I guess I'll try to re-install v11.1 properly first.
@Andavari: Very good idea. The Flash uninstaller should be available at Filehippo as well. But then the 32 bit and 64 bit uninstaller version should merged into one program and that's not the case, according to Adobe. Still some work to be done for Adobe. The wesbite has become (a bit) more user friendly.
Is there a good alternative to adobe flash player for wxp? That will open both website and local files? I would like to be totally free of adobe software. Thanks in advance.
Please be sure to place your opinions in Opinion tags
Adobe is not Malware, it's just at times badly written, full of holes and a multiplatform standard so a huge and BROAD malware vector. ( <----- See Not opinion solely facts )
I accept your correction.
I would however point out that the only mechanism I could depend upon to remove every trace of their download manager,
was the mechanism I will use if my system is ever infected with a virus,
Guess not. I have looked around quite a bit, cannot seem to find an effective replacement.
Pity.
Would really love to be wrong about that, and to be apprised of a good alternative.
