Additional temp folder cleaning
Every computer I use ccleaner on I have to manually include the application data temp folder.
Win 7: C:\Users\[username]\AppData\Local\Temp
XP: C:\Documents and Settings\[username]\Local Settings\Temp
ccleaner cleans out the Windows\Temp folder fine. Can we have an option added to include these additional temp folders? There are oftentimes several hundred MB of old temp files residing here that ccleaner does not normally touch.
would be a nice feature...
Make sure you don't have that Windows Temp 24 hours rule ticked in Options>Advanced
Don't forget on old XP this one too:
C:\Documents and Settings\LocalService\Local Settings\Temp
