Add Registry greyed out
Hello--when I go to options/exclude/add registry---I cannot add to it--the ok button is greyed out! I put 4 entries in previously--worked fine--am I just doing something stupid now?
Windows XP Home--SP3
Hi trwis, I've just remembered your post when I was posting earlier in another similar topic.
I don't know how the "Add Registry" worked in previous versions of CCleaner, because I never used it, but hopefully some part of the information from the other post may be of help.
http://forum.piriform.com/index.php?s=&amp...st&p=110229
Sometimes the registry exclude feature doesn't work, there's however a work around that I've used several times myself and it does work.
This is an example, of course you'd have to adapt it to exactly what you want to exclude.
