Add close to tray under system tray
Hi,
It would be perfect if they add Close to tray checkbox under options>System tray.I always close it thanks to my habit.
g'day husky and welcome to the forums.
Speccy already has Minimise to tray that still lets it run in the background so you can see your metrics.
wouldn't Close to tray just be the same as hitting the close X icon?
