Adblock removed after every use of Ccleaner
Hello,
Whenever I use the Ccleaner program my adblock on google Chrome gets removed and I have to manually re-install it.
I have tried several adblockers from the chrome shop and each and every one of them is removed after using Ccleaner.
Some info:
Windows 7 starter, 32 bit SP1
Google Chrome 33.0.1750.154 m
Currently using: AdBlock 2.6.26
Ccleaner v4.05.4250
Any info on how to prevent this from happening would be very welcome! I rather nog re-install my extentions every time I cleaned up my PC.
Thank you!
You should try the latest version of CCleaner which is v4.12.4657 (25 Mar 2014).
Do you use Winapp2.ini file?
I do not believe I do as I have no idea what that is.
However on this particular netbook (asus eee pc) I am using a free version, and upgrading means
I will have to purchase the program (again). I rather keep free software on this one.
You don't have to purchase anything, CCleaner is free.
If you've an option under chrome called HTML5 storage, please try unticking it. You must update your CCleaner to a more recent version (remember, CCleaner is free! and if you've paid for it, the updates for that are free for a year) because Chrome 32 changed some stuff around and older versions of CCleaner break newer versions of Chrome.
