ActiveX/COM Issue
it wouldn't let me paste here so I had to attach a notepad file so I wouldn't have to retype that file name....sorry
I have run the Registry Cleaner multiple times and it fixes everything but:
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Norton Internet Security\Engine64\20.4.0.40\McStatus.dll HKCR\CLSID{09D32393-10DA-4eca-91AA-AD11C69DB966}
I contacted Norton and they say everything is OK on their end but this .dll wont go away…any suggestions?
EDIT.. copy and pasted notepad file in for poster~ hazelnut
You posted about this once before in someone else's thread and were advised to start your own thread about it.
Did you see Nergal's comment and advice about what to do about this?
http://forum.piriform.com/index.php?showtopic=41855&do=findComment&comment=254677
Right click the entry and choose add to exclude list.
Short explanation : it's listed because, by design, your antivirus doesn't announce itself to the registration process so viruses can't disable it easily. The antivirus will immediately replace it if it is somehow removed.
