Everytime I use ccleaner regcleaner it hangs. I've nearrowed it down to a problem in the " active x and class issues" as all other options work fine. I am running the latest version of ccleaner v5.47 and windows 7. I am unsure how to fix this issue.
<ul><li>
Microsoft does not support the use of registry cleaners.
</li>
<li>
Microsoft is not responsible for issues caused by using a registry cleaning utility.
</li>
<li>
Microsoft cannot guarantee that problems resulting from the use of a registry cleaning utility can be solved.
</li>
</ul><p>
</blockquote>
</li>
