On my desktop I have a Pro plus licence valid until 24-6-27; on my android phone I have pro, valid until march 26. Now I want to upgrade my Android version with my licencekey, but i’m directed to the Google play paypage.
To activate CCleaner for Android using a multi-device key there is a button in the play store that you need to click that should then give you the option, see:
However, you say that you already have CCleaner Pro for Android valid until March - I assume you bought that in the Play Store in which case it doesn’t need a key - so it shouldn’t need your new multi-device key putting in until the current ‘paid to Google’ one expires.
When that happens just don’t renew it with Google but instead activate it with your multi-device key.
Hi @Harmen,
While you have a valid CCleaner Android licence from Google Play, it will always be automatically activated if you are logged in to the same Google Play account as the licence’s registered owner.
There is no difference in the app between these licences.
So I would advise you to allow the Google Play licence to expire then acctivate your CCleaner Professional Plus licence.
