Don't know about the drivers but you have the capability to make disks to restore the system just as it was from the factory.
Do you see the "Empowering Technology" icon? If not go into Programs and look for it. When brought up to the desktop there are several options listed and make restore disk is one of them. Usually will take two DVDs or 4-5 CDs. If things don't go well for you you can get the drive clear and then run the disks you made to get back to start one.
I have a 5610 and that's the way it works. Think your's will be the same.
thank you for your advice. I'm gonna try it soon. backup and make restore default disc in partion 2 and on cd's so I'm nervous to turn it to xp, but its better then vista so just save the fine the drivers by name and save it on my sd card or paration 2 also so wish me luck on upgrading to xp. can't i believe i got downgraded to vista
and also learning on how to restore from a partion.
but not yet reinstalling yet, I'm moving to another house to no connection, but thanks for the advice.
so keep you posted on my situation
love this site now, so friendly and very helpful, i recommended to many people
i turned it xp and it was faster no more waiting 1-2 minutes to load now, now 15-20 seconds.
thank you for your help mudd
all i did was downgrade the intel motherboard 7 + version to 6 + and everthing worked well
so all i need now is another 512 or 1gb ram and i'm pretty much happy
also partioned another section for backup incase i have to resinstall an go through all the pain and time to fix it again, thank you piriform forums for teaching me about partioning also
Glad you are pleased with your work and the Forum.
