About using Recuva after a partition format
is recuva able to recover files after the partition from which I wanna recover files has ben formated, and repartitioned in ntfs 3.1? like I reinstalled windows and forgot to save some files, so now they are gone, and I would like to recover them.... will this work?
Maybe, if you use Deep Scan, but I haven't heard of anyone running this to conclusion or what the results look like.
Deep scan is only effective if you have reformatted or partitioned using the same file system.
MrRon
