A small suggestion for ALL Piriform products
It's very small, just concerning install directory; wouldn't it be better to place products in a "C:\Program Files\Piriform\" directory by default, as well as placing Start Menu shortcuts in subdirectories under a "Piriform" directory?
That'd be awesome, especially a Start Menu "Piriform" subfolder - I just hate the "subfolder with only one thing in it" thing.
That would be great to some extent but maybe that does not allow users to install to a directory they like with this program and that. What I did was create a folder in the D: drive and put all my utility software there.
What I had suggested a long time back was a "Piriform Suite" thing with all of them combined; but I guess this could do :P
You might be mistaken as to what I'm asking for; right now Piriform products omit the "Piriform" directories I'm looking for and install under Program Files/Start Menu as is (so four install folders stuck in Program Files/on Start Menu).
Better for some, Not for all.
I think it makes sense. Just like Microsoft Office. :)
Only thing though is office is office. Each piriform product is individual. You uninstall office and they all go. So thats why the start menu works. Office - Applications
Prirforms would have to go Piriform - CCleaner - CCleaner.exe and so on. Id find this an annoyance. Small aanoyance i know, but one never the less.
Currently we have :
CCleaner
--CCleaner.exe
Defraggler
--Defraggler.exe
Recuva
--Recuva.exe
Speccy
--Speccy.exe
What he wants is this :
Piriform
--CCleaner.exe
--Defraggler.exe
--Recuva.exe
--Speccy.exe
That'd save space, and it wouldn't require more clicks.
So where would the documentation/uninstaller go for each app Aethec? It's why i said Piriform - CCleaner - CCleaner.exe
Obviously the devs can choose any way they like. I could also imagine some new users installing ccleaner then spending hours looking in the start menu for ccleaner and not realizing its under piriform.
The uninstaller doesn't need to go in the Start Menu. The Control Panel's Add/Remove Programs in XP or Programs and Features in Vista/7 already does that.
The documentation could be a single link "Piriform Documentation" pointing to docs.piriform.com ;)
The documentation could be a single link "Piriform Documentation" pointing to docs.piriform.com;)
+1
It is as it is, just simply all the folders are under Piriform.
Which is their own fault for not actually reading what the installation program tells them.
As much as it would be nice to live in a perfect world with perfect people we all make miss takes.
Computers are still very alien to some people and relying on just your own common sense for other people wont work.
Yes, I understand what you meant but I am only saying what I did on MY computer and basically, if all Piriform products let you install to a custom location, what you are asking is possible but you would have to manually direct them to this C:\Program Files\Piriform directory during their installment. But I personally think its not a big deal of concern but should do for those who like their folders grouped and sorted so neatly such as myself.
