a small problem
after i have run the CCleaner program to clear the user assist history now it don't put any new most used program at the start menu but it only put the pin ones
so is there any fix for the problem
If you want recently used programs to appear in the start menu, uncheck "User Assist History" before you run CCleaner again.
Windows will create a new list of recently used programs, but it will dissapear if you run CCleaner with that option enabled.
thanks for your help
