Hi Folks;
I'm running a Raid 1 configuration with 2 1TF drives. Can you confirm that C Cleaner Pro wipes both drives when I run it? Is the mirroring carried over to the cleaning of files on both?
Thanks
Narsonspose
184 views and no replies. Can anyone tell me if the problem is with the question or is it that nobody knows the answer? If nobody knows the answer, can someone please direct me to someone who does know the answer.
Thanks
Narsonspose
