A simple deep scan suggestion
Often times when i cant find what i look for in the normal scanning mode i do the 'deep scan', its an inconvenience to go through the options to turn it on and off, so my suggestion is to have a dedicated option or button somewhere on the main page, that's all. Something to think about in your next release :)
Also perhaps an auto scan option as the program starts, would shave off some time.
Good work with all of it so far :)
Cheers
If you run the Wizard (and haven't disabled it in the settings) the last screen before scanning begins will give you the option to enable a Deep Scan.
