A Sandboxie Question . . .
The way I have things set up on my computer is that when I download an mp3 file, it is supposed to open in my audio editing program. This setup works fine in Firefox (Un-Sandboxed) and in IE7.
However, when Firefox is Sandboxed, it doesn't work. The file appears to download -- then pauses -- then I get the error message about a problem with the audio editor and wanting to send this error report to Microsoft.
Any thoughts on how to make this routine work when Firefox is Sandboxed?
Hopefully Humpty will be around over the weekend, he's good with sandboxie.
Meanwhile you could always have a peep over on their forums.
Sorry Tom can't really help as I haven't had the same scenario to go by.
Hazel's advice in posting over at SB's forum should be beneficial.
Tzuk, the developer, is a decent fellow in trying to sort users probs plus there are some very capable helpers as well.
No need to register as you can post as a guest.
The thread "Official Version 3.00 and Later" is where to post and you can also download the latest beta from the sticky at the top which are usually stable.
SB's Forum
SB's Forum
Thanks, Humpty (and Hazel), I'll give that a try.
