everytime i run CCleaner, anylyze and "clean/fix", then close the program, then run it again, when i analyze this one always shows up..
C:\Documents and Settings\Daniel.DANIEL-OYT4R7U0\Local Settings\Temporary Internet Files\desktop.ini 67 bytes
C:\Documents and Settings\Daniel.DANIEL-OYT4R7U0\Local Settings\Temporary Internet Files\Content.IE5\desktop.ini 67 bytes
is it like that always?
Yes.
This is a frequently asked question that is not in the FAQ section yet. (MrG wink wink
There are many Windows files that will recreate themselves, which is normal behavior for Windows. Rest assured that it was in fact deleted the first time you told CCleaner to clean.
oooooooh.. hehe, thank you very much!!!
oh yeah, i also think that they should add this to the faq section..
again, thanks!!!
